Aller au contenu principal
Polar M400 Watch Battery Replacement
Ce dont vous avez besoin
  1. Polar M400 Watch Battery Replacement, Wrist Strap: étape 1, image 1 de 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: étape 2, image 1 de 2 Polar M400 Watch Battery Replacement: étape 2, image 2 de 2
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: étape 3, image 1 de 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: étape 4, image 1 de 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: étape 5, image 1 de 2 Polar M400 Watch Battery Replacement: étape 5, image 2 de 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: étape 6, image 1 de 2 Polar M400 Watch Battery Replacement: étape 6, image 2 de 2
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
15 autres ont terminé cette réparation.
Nicholas Sanders
Membre depuis le 09/28/17
513 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team S1-G3, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G3, Diaz Fall 2017
UMAINE-DIAZ-F17S1G3
4 membres
7 tutoriels rédigés
25 commentaires
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Réponse
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Réponse
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Réponse
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 53
30 derniers jours : 216
Total : 29,543
