Introduction
This guide will teach someone how to take out the battery in the Polar M400 and replace it with a working one. A damaged battery could be due to lack of charge or submersion in water more than 30 meters. It could also be due to battery age and various malfunctions. Over time, excessive and wear can lead to battery damage. The Polar M400 has an internal, rechargeable battery. You can charge the battery over 300 times or two years before a notable decrease in its capacity. The number of charge cycles also varies depending on use and operating conditions. Once the battery is replaced, follow local waste disposal regulations and do not dispose of this product as unsorted municipal waste.
Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
It may be easier to push the pins out in one direction. Unfortunately, I do not recall which direction was easier…
Nathan Gelderloos - Reply
Apply an upward pressure to the holes until the locking pins release. Use precision tweezers to remove the pins that connect the face with the strap.
  • Apply an upward pressure to the holes until the locking pins release.
  • Use precision tweezers to remove the pins that connect the face with the strap.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Once the pins are released, the old wrist strap should snap off.
  • Once the pins are released, the old wrist strap should snap off.
  • Simply lock the new wrist strap into place.
Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
Gently remove the backing from the watch. Gently remove the backing from the watch.
  • Gently remove the backing from the watch.
Use tweezers to gently pry the golden sensor away from the battery. Remove battery using the plastic opening tools.
  • Use tweezers to gently pry the golden sensor away from the battery.
  • Remove battery using the plastic opening tools.
3 other people completed this guide.
Nicholas Sanders
249 Reputation
2 Guides authored
One Comment
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Reply
Past 24 Hours: 7
Past 7 Days: 87
Past 30 Days: 422
All Time: 1,617
