Aller au contenu principal
Polar V800 Charging Port Cover Replacement
Ce dont vous avez besoin
  1. Polar V800 Charging Port Cover Replacement, Watch Band: étape 1, image 1 de 3 Polar V800 Charging Port Cover Replacement, Watch Band: étape 1, image 2 de 3 Polar V800 Charging Port Cover Replacement, Watch Band: étape 1, image 3 de 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: étape 2, image 1 de 3 Polar V800 Charging Port Cover Replacement: étape 2, image 2 de 3 Polar V800 Charging Port Cover Replacement: étape 2, image 3 de 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: étape 3, image 1 de 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: étape 3, image 2 de 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: étape 3, image 3 de 3
    • Take off the charging port cover.
Nick B.
Membre depuis le 04/29/18
387 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G6, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 membres
8 tutoriels rédigés
Un commentaire
where does not procure the battery port cover ?
Chenthill P - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,926
