Introduction
This guide will show you how to replace the lens on your Polaroid camera if it breaks or gets scratched. However, you should be careful with your Polaroid, as the plastic is very fragile.
Pièces
Aucune pièce nécessaire.
Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal. Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal. Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
Ajouter un commentaire
Separate the flash section of the camera from the main body by unhooking the sides with the spudger. BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM! BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
  • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
Fully open the battery/ cartridge compartment by sliding the side tab toward you. Fully open the battery/ cartridge compartment by sliding the side tab toward you. Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
Insert spudger in between face of camera and sides where the four tabs are located. BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step. BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  • Insert spudger in between face of camera and sides where the four tabs are located.
  • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
Once tabs are released, pull face of camera straight out. Once tabs are released, pull face of camera straight out.
  • Once tabs are released, pull face of camera straight out.
Use spudger to twist the notch on the lens into the opening to remove it.
  • Use spudger to twist the notch on the lens into the opening to remove it.
Carefully use spudger to release lens, then lift lens out of camera with fingers. CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  • Carefully use spudger to release lens, then lift lens out of camera with fingers.
  • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
  • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
6 autre(s) ont terminé cette réparation.
Doug Jimenez
Membre depuis le 21/01/2010
400 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 16-31, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 membres
4 tutoriels rédigés
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 37
30 derniers jours : 135
Total : 11,463
