Aller au contenu principal
Polaroid Onestep Close Up Primary Lens Replacement
Ce dont vous avez besoin
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: étape 1, image 1 de 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: étape 1, image 2 de 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: étape 1, image 3 de 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: étape 2, image 1 de 2 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: étape 2, image 2 de 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: étape 3, image 1 de 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: étape 3, image 2 de 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: étape 3, image 3 de 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: étape 4, image 1 de 1
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: étape 5, image 1 de 2 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: étape 5, image 2 de 2
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
3 autres ont terminé cette réparation.
Christopher Collazo
Membre depuis le 09/22/14
318 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 11
Total : 1,419
