Aller au contenu principal
Polaroid i533 Button Replacement
Ce dont vous avez besoin
  1. Polaroid i533 Button Replacement, Button: étape 1, image 1 de 3 Polaroid i533 Button Replacement, Button: étape 1, image 2 de 3 Polaroid i533 Button Replacement, Button: étape 1, image 3 de 3
    • Using a #00 screw driver, remove all of the screws on the body of the camera. There are 9 screws total on the face of the camera
    • All of the screws used in the Polaroid i533 are the same size
    • Be sure to not misplace any screws as you will need them to put the camera back together.
  2. Polaroid i533 Button Replacement: étape 2, image 1 de 2 Polaroid i533 Button Replacement: étape 2, image 2 de 2
    • Slide open the battery door, then using the plastic opening tool, slightly open the side of the camera case.
    • Gently pull apart the cover from the body of the camera.
    • Do not pull the cover off completely because it is still attached to the logic board.
  3. Polaroid i533 Button Replacement: étape 3, image 1 de 3 Polaroid i533 Button Replacement: étape 3, image 2 de 3 Polaroid i533 Button Replacement: étape 3, image 3 de 3
    • Locate the black tab where the LCD screen ribbon is attached to the logic board.
    • Using the plastic opening tool, flip the black tab towards the ribbon.
    • Gently pull the ribbon away from the logic board.
  4. Polaroid i533 Button Replacement: étape 4, image 1 de 1
    • The back half of the camera with the LCD screen should now be separated from the front casing.
    • If you are experiencing problems with your menu buttons, you must replace the entire back half of the outer case (Not including the screen). move on to step 5.
    • If you are experiencing problems only with your snap button (the one that you push to take pictures), skip ahead to step 7.
  5. Polaroid i533 Button Replacement: étape 5, image 1 de 1
    • Using a #00 screwdriver, remove the four screws located at each corner of the LCD screen.
  6. Polaroid i533 Button Replacement: étape 6, image 1 de 1
    • Remove the LCD screen from the old casing.
    • attach the LCD screen to the new casing using the screws removed in step 5.
  7. Polaroid i533 Button Replacement: étape 7, image 1 de 2 Polaroid i533 Button Replacement: étape 7, image 2 de 2
    • Using a #00 screw driver, remove the screw on the bottom of the logic board just above the tripod attachment.
    • Gently pull the front of the case away from the insides of the camera.
  8. Polaroid i533 Button Replacement: étape 8, image 1 de 2 Polaroid i533 Button Replacement: étape 8, image 2 de 2
    • Locate the button that will be removed.
    • To remove: gently push outward on the button from the inside of the casing.
  9. Polaroid i533 Button Replacement: étape 9, image 1 de 1
    • Remove spring from bottom of broken button.
    • Remove and replace defective button.
    • Do not lose spring as it is needed for replacement button.
Terichael Office
Membre depuis le 06/24/10
9 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-4, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 9
Total : 2,365
