Introduction
When the screen on your camera breaks, the whole camera becomes unusable. This guide will show you how to replace the LCD screen on a Polaroid i533 camera.
Pièces
Aucune pièce nécessaire.
On the left-hand side of the camera screen, unscrew and remove the four 3mm screws, as shown in the photograph. On the right-hand side of the camera screen, unscrew and remove the two 3mm screws. On the bottom of the camera, unscrew and remove the three 3mm screws.
  • On the left-hand side of the camera screen, unscrew and remove the four 3mm screws, as shown in the photograph.
  • On the right-hand side of the camera screen, unscrew and remove the two 3mm screws.
  • On the bottom of the camera, unscrew and remove the three 3mm screws.
Ajouter un commentaire
Slide the battery door open and 'slightly' open the side of the case with the iFixit plastic opening tool.
  • Slide the battery door open and 'slightly' open the side of the case with the iFixit plastic opening tool.
Be careful not to pull the cover off completely, it is still attached to the logic board.
  • Be careful not to pull the cover off completely, it is still attached to the logic board.
  • Gently pull the cover away from the rest of the camera. Do not separate the pieces completely.
Locate where the LCD screen ribbon is attached to the logic board. With the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the logic board.
  • Locate where the LCD screen ribbon is attached to the logic board.
  • With the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the logic board.
Gently pull the ribbon away from the logic board. You can now separate the cover from the rest of the camera.
  • Gently pull the ribbon away from the logic board. You can now separate the cover from the rest of the camera.
Locate the four screws in each corner of the LCD screen, unscrew and remove them. Keep them separate from the 3mm case screws.
  • Locate the four screws in each corner of the LCD screen, unscrew and remove them. Keep them separate from the 3mm case screws.
Remove the LCD screen from the remaining casing of the camera.
  • Remove the LCD screen from the remaining casing of the camera.
ashley
Membre depuis le 24/06/2010
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-4, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 64
Total : 2,954
