Aller au contenu principal
Polaroid i533 LCD Screen Replacement
Ce dont vous avez besoin
  1. Polaroid i533 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 3 Polaroid i533 LCD Screen Replacement, LCD Screen: étape 1, image 2 de 3 Polaroid i533 LCD Screen Replacement, LCD Screen: étape 1, image 3 de 3
    • Remove the four 3mm screws from the left-hand side of the camera screen.
    • On the right-hand side of the camera screen, unscrew and remove the two 3mm screws.
    • On the bottom of the camera, unscrew and remove the three 3mm screws.
  2. Polaroid i533 LCD Screen Replacement: étape 2, image 1 de 1
    • Slide the battery door open and slightly open the side of the case with a plastic opening tool.
  3. Polaroid i533 LCD Screen Replacement: étape 3, image 1 de 1
    • Be careful not to pull the cover off completely, as it should remain attached to the motherboard.
    • Gently pull the cover away from the rest of the camera. Do not separate the pieces completely.
  4. Polaroid i533 LCD Screen Replacement: étape 4, image 1 de 2 Polaroid i533 LCD Screen Replacement: étape 4, image 2 de 2
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the motherboard.
  5. Polaroid i533 LCD Screen Replacement: étape 5, image 1 de 1
    • Gently pull the ribbon away from the motherboard. This will allow the cover to separate from the rest of the camera.
  6. Polaroid i533 LCD Screen Replacement: étape 6, image 1 de 1
    • Locate the four screws in each corner of the LCD screen and carefully remove them. After they have been removed, ensure the screws stay separate from the 3mm case screws.
  7. Polaroid i533 LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the LCD screen from the remaining casing of the camera.
ashley
Membre depuis le 06/24/10
19 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-4, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 membres
8 tutoriels rédigés
Un commentaire
great job and information
John Webb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 3,674
