Introduction
A common problem users have with this phone is difficulty locating and replacing the battery. This guide will take you through the steps of finding and replacing the battery.
Hold the mouthpiece of the handset and locate the lock-unlock text. Twist the battery cover counterclockwise from the "lock" to the "unlock" position. Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
  • Hold the mouthpiece of the handset and locate the lock-unlock text.
  • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
Ajouter un commentaire
To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket. To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket. To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
  • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
Pull the battery from the battery compartment. You may need to gently wiggle the battery back and forth in its compartment to help loosen it. You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
  • Pull the battery from the battery compartment.
  • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
2 autre(s) ont terminé cette réparation.
Tia
Membre depuis le 27/10/2014
453 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 15
Total : 595
