Introduction
Replacing the internal battery which regulates several functions in the computer, including the calendar.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Pull on outer latch. Lower door until it is level with your work surface.
  • Pull on outer latch.
  • Lower door until it is level with your work surface.
  • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Ajouter un commentaire
Locate the battery. Remove and replace battery.
  • Locate the battery.
  • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Ligne d'arrivée
14 autre(s) ont terminé cette réparation.
Justin Petrilli
Membre depuis le 21/01/2010
2 598 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
13 tutoriels rédigés
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 87
Total : 16,236
