Aller au contenu principal
Power Mac G4 M5183 Main Fan Replacement
Ce dont vous avez besoin
  1. Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 1 de 2 Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Main Fan Replacement, Main Fan: étape 2, image 1 de 2 Power Mac G4 M5183 Main Fan Replacement, Main Fan: étape 2, image 2 de 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Power Mac G4 M5183 Main Fan Replacement: étape 3, image 1 de 1
    • Remove the power cable from the fan and detach bracing.
  4. Power Mac G4 M5183 Main Fan Replacement, Main Fan: étape 4, image 1 de 1
    • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
3 autres ont terminé cette réparation.
Stephen Scruggs
Membre depuis le 01/20/10
2 238 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 37
Total : 7,724
