Aller au contenu principal
Power Mac G5 Front Fan Assembly Replacement
  1. Power Mac G5 Front Fan Assembly Replacement, Side Panel: étape 1, image 1 de 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Front Fan Assembly Replacement: étape 2, image 1 de 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Front Fan Assembly Replacement: étape 3, image 1 de 2 Power Mac G5 Front Fan Assembly Replacement: étape 3, image 2 de 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Front Fan Assembly Replacement: étape 4, image 1 de 3 Power Mac G5 Front Fan Assembly Replacement: étape 4, image 2 de 3 Power Mac G5 Front Fan Assembly Replacement: étape 4, image 3 de 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Front Fan Assembly Replacement, Front Fan Assembly: étape 5, image 1 de 1
    • Locate the front fan assembly.
  6. Power Mac G5 Front Fan Assembly Replacement: étape 6, image 1 de 1
    • Pull the fan assembly out; it should slide out easily.
25 autres ont terminé cette réparation.
Adam
Membre depuis le 01/22/10
831 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-8, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 18,876
