Introduction
These next steps will guide you to correctly installing the graphics card in your computer.
Pièces
Aucune pièce nécessaire.
To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
  • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
  • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
Ajouter un commentaire
Remove all the cables, including the power cables before opening the unit.
  • Remove all the cables, including the power cables before opening the unit.
Lift the tab to unlock the side panel. The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  • Lift the tab to unlock the side panel.
  • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle. Remove the air deflector (the clear plastic cover) by pulling on the handle.
  • Remove the air deflector (the clear plastic cover) by pulling on the handle.
Locate the graphics card in the desktop.
  • Locate the graphics card in the desktop.
Using a Phillips # 1 screw driver, unscrew the screw right next to the graphics card. Using a Phillips # 1 screw driver, unscrew the screw right next to the graphics card.
  • Using a Phillips # 1 screw driver, unscrew the screw right next to the graphics card.
Last thing to do is to gently shake the card out of it's slot by pulling it straight out.  (If  the card does not come out easily, don't force it. You need to release a latch on the logic board behind the AGP connector while pulling out the video card.)
  • Last thing to do is to gently shake the card out of it's slot by pulling it straight out. (If the card does not come out easily, don't force it. You need to release a latch on the logic board behind the AGP connector while pulling out the video card.)
34 autre(s) ont terminé cette réparation.
Salvador Aguilar
Membre depuis le 21/01/2010
2 337 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-8, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 membres
11 tutoriels rédigés
hello, i’m wondering what’s the maxi ram of graphic card can be accepted by g5? we know it can do 128m 256m in standard, but what if we install a 512m or even 1go ram graphic card, it there anyone who has tried please? thank you!
qian daniel - Réponse
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 44
30 derniers jours : 152
Total : 36,120
