Aller au contenu principal
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Ce dont vous avez besoin
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: étape 1, image 1 de 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: étape 1, image 2 de 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: étape 2, image 1 de 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: étape 3, image 1 de 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: étape 3, image 2 de 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: étape 3, image 3 de 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: étape 4, image 1 de 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
13 autres ont terminé cette réparation.
Faizan Naveed
Membre depuis le 04/12/17
3 294 Réputation
8 tutoriels rédigés
Équipe
Mobile Device Repair Factory Membre de l'équipe Mobile Device Repair Factory
Business
1 membre
16 tutoriels rédigés
5 commentaires
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Réponse
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Réponse
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Réponse
My bettry is too good work but tha wireis want to b change
Asoo Malik - Réponse
Plzz tel me how I can change tha wire of my power beats
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 102
Total : 28,843
