Aller au contenu principal
PowerBook 180 Modem Replacement
Ce dont vous avez besoin
  1. PowerBook 180 Modem Replacement, Modem: étape 1, image 1 de 2 PowerBook 180 Modem Replacement, Modem: étape 1, image 2 de 2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: étape 2, image 1 de 2 PowerBook 180 Modem Replacement: étape 2, image 2 de 2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: étape 3, image 1 de 2 PowerBook 180 Modem Replacement: étape 3, image 2 de 2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: étape 4, image 1 de 2 PowerBook 180 Modem Replacement: étape 4, image 2 de 2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
3 autres ont terminé cette réparation.
Jack Byrnes
Membre depuis le 10/17/10
1 244 Réputation
2 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 468 tutoriels rédigés
Un commentaire
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 1,627
