Aller au contenu principal
PowerBook 180 Ram Replacement
Ce dont vous avez besoin
  1. PowerBook 180 Ram Replacement, Ram: étape 1, image 1 de 2 PowerBook 180 Ram Replacement, Ram: étape 1, image 2 de 2
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: étape 2, image 1 de 2 PowerBook 180 Ram Replacement: étape 2, image 2 de 2
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: étape 3, image 1 de 2 PowerBook 180 Ram Replacement: étape 3, image 2 de 2
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: étape 4, image 1 de 1
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: étape 5, image 1 de 2 PowerBook 180 Ram Replacement: étape 5, image 2 de 2
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
3 autres ont terminé cette réparation.
Jack Byrnes
Membre depuis le 10/17/10
1 244 Réputation
2 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 23
Total : 3,174
