Introduction
You can easily remove the floppy drive in order to repair or upgrade it.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
  • Close the screen and turn the PowerBook over. Orient the computer so the text of the label is right side up.
Ajouter un commentaire
Press and hold the button on the left of the front side and slide the battery out. Press and hold the button on the left of the front side and slide the battery out.
  • Press and hold the button on the left of the front side and slide the battery out.
First, slide the switch on the back of the computer to the left. Then pull the floppy drive out of the computer.
  • First, slide the switch on the back of the computer to the left.
  • Then pull the floppy drive out of the computer.
Michael Mondragon
Membre depuis le 12/04/2011
115 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 24-59, Amido Spring 2011 Membre de l'équipe Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 1,459
