Introduction
Small metal finger located beneath the memory door.
Use a coin to turn the battery locking screw 90 degrees to the right.
  • Use a coin to turn the battery locking screw 90 degrees to the right.
  • Lift the battery out of the computer.
Ajouter un commentaire
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the four Phillips screws from the memory door.
  • Remove the four Phillips screws from the memory door.
  • Slide the memory door away from the memory compartment.
Remove the long black Phillips screw next to the memory card.
  • Remove the long black Phillips screw next to the memory card.
  • Remove the small EMI finger beneath the black screw.
4 autre(s) ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
745 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 4,058
