Introduction
Tripped over your power cord? At least you don't have to replace the entire logic board.
Orient the computer so that the side with the line of screws on it is away from you.
  • Orient the computer so that the side with the line of screws on it is away from you.
  • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
  • Lift the battery out of the computer.
Which screw driver I have to use here?
smartvideocanada - Réponse
Phillips #00 Screwdriver: All necessary tools are available to buy at the top of this page if they are needed.
Sam Love -
Remove the three identical Phillips screws from the memory door.
  • Remove the three identical Phillips screws from the memory door.
Ajouter un commentaire
Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
  • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Release the tabs on each side of the RAM chip at the same time.  These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
  • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
  • 2) After disengaging the locking bar, slide the cable out of the connector.
Where can I get a replacement clip for the ribbon cable?
applerepairshop - Réponse
For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
  • For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
  • Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
  • Slide the trackpad cable out of the loosened connector.
  • When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
  • Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
Remove the following 10 screws from the bottom case:
  • Remove the following 10 screws from the bottom case:
    • Three 1.7 mm Phillips from the front edge of the battery compartment.
    • One 3.9 mm T8 Torx to the right of the memory card.
    • One 6.9 mm T8 Torx at the left edge of the memory compartment.
    • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
    • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
i believe that you have the torx screws reversed here. The longer one should go on the left and vise versa.
spatz - Réponse
oops, my bad. You're right.
spatz - Réponse
  • Turn the computer over and rotate it so that the DVI port faces you.
  • Remove the four identical Phillips screws spread along this edge of the case.
  • Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
Open the computer and turn it so that the screen faces you.
  • Open the computer and turn it so that the screen faces you.
  • Pull the upper case off, lifting from the back, and working around the edges.
Use a spudger to loosen the casing if it sticks.
  • Use a spudger to loosen the casing if it sticks.
  • Once the casing is entirely free, lift it off of the computer.
BE VERY CAREFUL when replacing the keyboard to thread the keyboard ribbon cable through the slot. The steps didn't appear to make this warning and when I replaced all screws, found that it was jammed and would not come through to connect with the connector. I had to undo a lot of steps to go back and rethread it properly.
Ted - Réponse
Use the method described in the step for disconnecting the keyboard ribbon to loosen the connector on the DC-In board.
  • Use the method described in the step for disconnecting the keyboard ribbon to loosen the connector on the DC-In board.
  • Pull the cable free of the loosened connector.
Remove the single Phillips screw from the Bluetooth board.
  • Remove the single Phillips screw from the Bluetooth board.
Lift the Bluetooth board partially out of the computer and disconnect the attached antenna cable.
  • Lift the Bluetooth board partially out of the computer and disconnect the attached antenna cable.
The antenna pulls out from the top,not sideways
sieg deleu - Réponse
Disconnect the black speaker cable from the sound board.
  • Disconnect the black speaker cable from the sound board.
Remove the single T8 Torx screw from the left speaker assembly.
  • Remove the single T8 Torx screw from the left speaker assembly.
Disconnect the orange DC-In cable from the logic board.
  • Disconnect the orange DC-In cable from the logic board.
Deroute the cables from the right side of the speaker and lift it off of the logic board.
  • Deroute the cables from the right side of the speaker and lift it off of the logic board.
Disconnect the rainbow power cable from the DC-In board.
  • Disconnect the rainbow power cable from the DC-In board.
Disconnect the black and white RJ-11 cable from the top, right corner of the modem.
  • Disconnect the black and white RJ-11 cable from the top, right corner of the modem.
Remove the two identical T8 Torx screws from the DC-In board.
  • Remove the two identical T8 Torx screws from the DC-In board.
Slide the DC-In board to the right and lift it out of the computer.
  • Slide the DC-In board to the right and lift it out of the computer.
  • If the DC-In board sticks, you may need to remove the T8 screw next to the DC-In board to free it.
20 autre(s) ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
745 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 20,961
