Introduction
The secondary fan, included on 800 MHz and faster PowerBook DVI machines.
Ce dont vous avez besoin
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the RAM chip out.
Repeat this process if a second RAM chip is installed.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Disconnect the large DC-In connector from the right side of the logic board.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
Disconnect the four indicated connectors from the logic board.
Turn the G4 over.
Remove the seven T8 Torx screws from the logic board.
Disconnect the 5 indicated connectors from the logic board, removing tape as necessary.
Reassembly Tip: Reseating the logic board will be much easier if you use kapton tape to hold these five connectors out of the way until it is in place.
Caution: If taping the connectors back, be careful not to use tape with anything but very weak adhesive (i.e. kapton tape). Even electrical tape can pull the paint off the hinges when removed.
Remove the two T8 Torx screws that secure the PC Card cage.
Remove the 4 mm hex nut from the PC Card cage.
3 autres ont terminé cette réparation.
Pièces jointes
Un commentaire
I believe that the second fan goes in the empty slot (on the 667 model) next to the DC in port.
