Introduction
Install an original Airport 802.11b card internally.
Pièces
  • Turn the G4 over.
  • Remove the eight T8 Torx screws from the lower case.
Ajouter un commentaire
Using your thumbs, slide the lower case away from you.
  • Using your thumbs, slide the lower case away from you.
  • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Your laptop should look approximately like this.
  • Your laptop should look approximately like this.
Skip this step if your computer does not have an Airport card.
  • Skip this step if your computer does not have an Airport card.
  • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
  • Disconnect the antenna cable from the left side of the Airport card.
I'm not sure what the point is for this step. This helped not at all in getting the drive out. Also, the cable is taped down, and must be untaped before the card will come out.
Calion - Réponse
5 autre(s) ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
745 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 7
Total : 8,887
