Introduction
Removing the graphics card.
Pièces
Aucune pièce nécessaire.
Pull on outer latch. Lower door until it is level with your work surface.
  • Pull on outer latch.
  • Lower door until it is level with your work surface.
  • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Ajouter un commentaire
Remove the single screw with the Phillips #1 screwdriver. Pull the graphics card up and out.
  • Remove the single screw with the Phillips #1 screwdriver.
  • Pull the graphics card up and out.
Ligne d'arrivée
11 autre(s) ont terminé cette réparation.
Justin Petrilli
Membre depuis le 21/01/2010
2 598 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
13 tutoriels rédigés
Do I need to avoid static to protect the board?
Jim Robson - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 7,960
