Ce dont vous avez besoin
Remove the head pillow by simply peeling it back . Its only attached with Velcro.
Next unzip the very top zipper.
remove nut using a wrench . There should also be a small washer but they usually get stuck inside , they should fall out during the next step.
Next this bolt will need to be tapped out . you can either LIGHTLY tap it with a wrench from the threaded end ( see last step) or you can use vice grips .
To reassemble your device, follow these instructions in reverse order. Be sure you are putting your zip ties in reasonable places , you don't need to use as many as the factory has used . Just be smart about the placement making sure wires are not in pinch point areas .
Un commentaire
Hi Nick is there any way I can contact you to ask about a part that im looking for for a massage chair im trying to repair? its an easy fix but i cannot for the life of me find the product or what its called - if possible please contact me a_hammond@outlook.com it would be much appreciated
