Aller au contenu principal
ProLine HB25 Disassembly
Ce dont vous avez besoin
  1. ProLine HB25 Disassembly, ProLine HB25 Disassembly: étape 1, image 1 de 1
    • Unscrew the screw on the back of the product.
  2. ProLine HB25 Disassembly: étape 2, image 1 de 2 ProLine HB25 Disassembly: étape 2, image 2 de 2
    • Pull out the backtab of the housing.
    • Push in the snapfits with, for instance, a screwdriver.
  3. ProLine HB25 Disassembly: étape 3, image 1 de 2 ProLine HB25 Disassembly: étape 3, image 2 de 2
    • Separate the housing with calibrated force.
    • Keep your fingers away from the housing and do not bend or break the housing.
    • Use a flathead screwdriver to push out the lower function button.
    • Remove the separating device.
  4. ProLine HB25 Disassembly: étape 4, image 1 de 1
    • Unscrew the hidden screw under the button.
  5. ProLine HB25 Disassembly: étape 5, image 1 de 2 ProLine HB25 Disassembly: étape 5, image 2 de 2
    • Open the housing.
    • Unscrew the circuit board.
    • Unscrew the wire lock.
  6. ProLine HB25 Disassembly: étape 6, image 1 de 2 ProLine HB25 Disassembly: étape 6, image 2 de 2
    • Push the housing of the button out of the housing.
  7. ProLine HB25 Disassembly: étape 7, image 1 de 2 ProLine HB25 Disassembly: étape 7, image 2 de 2
    • Push on the side of the housing of the button to push the button out of the housing.
    • The spring can jump away when you push out the button.
Jorma van Dalen
Membre depuis le 03/07/18
175 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 270
