Aller au contenu principal
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
Ce dont vous avez besoin
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: étape 1, image 1 de 2 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: étape 1, image 2 de 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: étape 2, image 1 de 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): étape 3, image 1 de 1
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: étape 4, image 1 de 1
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: étape 5, image 1 de 1
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Matthew Selting
Membre depuis le 02/15/18
432 Réputation
4 tutoriels rédigés
Équipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 141
