Introduction
Use this guide to disconnect the battery from the your Protocol TerraCopter Evo. You will need to flip your drone upside down then unlock the battery cover by pulling the plastic trigger down and open it then remove it by disconnect it from the drone's cable.
Outils
Aucun outil requis.
Pièces
Pull down the battery cover on the bottom of the drone and open it. Pull down the battery cover on the bottom of the drone and open it.
  • Pull down the battery cover on the bottom of the drone and open it.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull the battery out of the battery slot. Disconnect the red battery cable from the device. Disconnect the red battery cable from the device.
  • Pull the battery out of the battery slot.
  • Disconnect the red battery cable from the device.
Remove the battery from the device.
  • Remove the battery from the device.
Tri Luong
Membre depuis le 17/01/2018
327 Réputation
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 54
