Aller au contenu principal
Protocol TerraCopter EVO Front Wheels Replacement
Ce dont vous avez besoin
  1. Protocol TerraCopter EVO Front Wheels Replacement, Propellers: étape 1, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the four screws connecting the propellers to the device.
  2. Protocol TerraCopter EVO Front Wheels Replacement: étape 2, image 1 de 2 Protocol TerraCopter EVO Front Wheels Replacement: étape 2, image 2 de 2
    • Hold the propellers gently and pull the propellers out of the drone .
  3. Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: étape 3, image 1 de 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: étape 3, image 2 de 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: étape 3, image 3 de 3
    • Use a plastic opening tool or a spudger to separate the drone's cover from the body of the drone.
    • Remove the connector of the drone body and the back wheels using a plastic opening tool.
  4. Protocol TerraCopter EVO Front Wheels Replacement: étape 4, image 1 de 2 Protocol TerraCopter EVO Front Wheels Replacement: étape 4, image 2 de 2
    • Use the opening tool to separate the drone's body from the drone's shock absorber.
  5. Protocol TerraCopter EVO Front Wheels Replacement: étape 5, image 1 de 3 Protocol TerraCopter EVO Front Wheels Replacement: étape 5, image 2 de 3 Protocol TerraCopter EVO Front Wheels Replacement: étape 5, image 3 de 3
    • Hold the wheels gently then pull it out of the drone's lower board wheels connector.
    • Repeat the same step for the other front wheel.
Tri Luong
Membre depuis le 01/17/18
327 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 123
