Aller au contenu principal
Protocol Vento Motor Replacement
Ce dont vous avez besoin
  1. Protocol Vento Motor Replacement, Battery: étape 1, image 1 de 1
    • Grasp the tail end of the drone where the lip of the battery protrudes.
  2. Protocol Vento Motor Replacement: étape 2, image 1 de 1
    • Pull away from the drone to remove the battery.
    • Do not attempt any repairs or replacements before removing the battery from the drone.
  3. Protocol Vento Motor Replacement, Propeller: étape 3, image 1 de 1
    • Place a prying tool under the base of the propeller.
  4. Protocol Vento Motor Replacement: étape 4, image 1 de 2 Protocol Vento Motor Replacement: étape 4, image 2 de 2
    • Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
  5. Protocol Vento Motor Replacement, Motor: étape 5, image 1 de 1
    • Unscrew the 4.9mm Phillips #000 screw that is located at the end of the drone's arm.
  6. Protocol Vento Motor Replacement: étape 6, image 1 de 2 Protocol Vento Motor Replacement: étape 6, image 2 de 2
    • Hold the base of the arm while gently pulling the motor cover away from the arm.
    • Do not pull too hard because there are wires attaching the motor to the drone. Do not sever the wires.
  7. Protocol Vento Motor Replacement: étape 7, image 1 de 2 Protocol Vento Motor Replacement: étape 7, image 2 de 2
    • Gently pull the motor out from the plastic cover.
    • Do not squeeze or pull too hard, as to not damage the motor connection.
  8. Protocol Vento Motor Replacement: étape 8, image 1 de 2 Protocol Vento Motor Replacement: étape 8, image 2 de 2
    • The motor’s blue and red wires are secured via a white clip. This clip is inserted into a slot in the drone’s leg.
    • Grasp the clip’s edges with a pair of tweezers and pull outward.
    • Do not pull directly on the wires, as to not separate the wires from the clip.
4 autres ont terminé cette réparation.
Maria Larcomb
Membre depuis le 02/15/18
926 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G2, Leahy Spring 2018 Membre de l'équipe USF Tampa, Team S1-G2, Leahy Spring 2018
USFT-LEAHY-S18S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 647
