Introduction
The Pyle Astro's power button is a simple push button switch that is soldered onto the main PCB. Use this guide to replace your tablet's power button.
Using the plastic opening tool, work your way along the edge of the tablet. The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
  • Using the plastic opening tool, work your way along the edge of the tablet.
  • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
  • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
  • Place the front display assembly facing front side down to expose the inside.
Ajouter un commentaire
Remove the three 4 mm JIS #0 screws to release the PCB board. Remove the three 4 mm JIS #0 screws to release the PCB board.
  • Remove the three 4 mm JIS #0 screws to release the PCB board.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Flip the PCB board upside down to expose the solder joints for the power button.
Install the new push button switch and solder all the connections back into place.
Andrew Redifer
Membre depuis le 27/03/2018
265 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G6, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 22
