Introduction
Use this guide to replace the power port of the RCA Lyra X2400.
Using slight pressure with your finger on the word "OPEN", slide the battery plate down. Remove the battery plate. Place your finger at the bottom of the battery.
  • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
  • Remove the battery plate.
  • Place your finger at the bottom of the battery.
  • Lift up on the battery until it pops out from the LYRA X2400.
Ajouter un commentaire
Remove two Phillips screws from the silver cover at the top of the Lyra. Slowly wiggle the silver cover while pulling it away from the device.
  • Remove two Phillips screws from the silver cover at the top of the Lyra.
  • Slowly wiggle the silver cover while pulling it away from the device.
Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button. Pull the silver case from the bottom of the device.
  • Remove two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
  • Pull the silver case from the bottom of the device.
Carefully pry up the screen with a plastic opening tool. Disconnect the screen's ribbon cable  from the circuit board. Remove the screen.
  • Carefully pry up the screen with a plastic opening tool.
  • Disconnect the screen's ribbon cable from the circuit board.
  • Remove the screen.
Open the case of the Lyra. Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
  • Open the case of the Lyra.
  • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Locate the DC power adaptor component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located. Start using solder/desolder tools to remove the DC power adaptor.
  • Locate the DC power adaptor component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
  • Start using solder/desolder tools to remove the DC power adaptor.
  • Once removed replace it with the new working DC power adaptor.
    • Use the soldering tools to reattach the component back to the main logic board.
Joseph Goodwin
Membre depuis le 11/04/2013
1 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-3, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 105
