Introduction
This guide will show how to replace the LCD screen on the RCA RCR8622.
Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides. Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver. A magnetic screwdriver will help you remove the screws from their slots.
  • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
  • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
Ajouter un commentaire
Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device. Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out  with the tweezers to disconnect. Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out  with the tweezers to disconnect.
  • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
  • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
Grab the speaker and pull upward. The Speakers will be loose. Repeat this step with the other speaker.
  • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver. Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard. Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
  • Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
  • Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
Lift the motherboard out of the interior of the device. Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards. Both sections will be connected with a ribbon connection.
  • Lift the motherboard out of the interior of the device.
  • Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards.
  • Both sections will be connected with a ribbon connection.
Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen. Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins. Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
  • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
Lift the screen upward, taking care not to allow the films below it to fall out. Lift the screen upward, taking care not to allow the films below it to fall out.
  • Lift the screen upward, taking care not to allow the films below it to fall out.
Josh Excell
Membre depuis le 20/03/2018
449 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S6-G5, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 15
Total : 47
