Aller au contenu principal
RCA RCR8622 Speaker Replacement
Ce dont vous avez besoin
  1. RCA RCR8622 Speaker Replacement, Speaker: étape 1, image 1 de 3 RCA RCR8622 Speaker Replacement, Speaker: étape 1, image 2 de 3 RCA RCR8622 Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 Speaker Replacement: étape 2, image 1 de 3 RCA RCR8622 Speaker Replacement: étape 2, image 2 de 3 RCA RCR8622 Speaker Replacement: étape 2, image 3 de 3
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 Speaker Replacement: étape 3, image 1 de 2 RCA RCR8622 Speaker Replacement: étape 3, image 2 de 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
Josh Excell
Membre depuis le 03/20/18
449 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S6-G5, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 302
