Aller au contenu principal
RCA RCT6303W87 Battery Replacement
Ce dont vous avez besoin
  1. RCA RCT6303W87 Battery Replacement, Battery: étape 1, image 1 de 3 RCA RCT6303W87 Battery Replacement, Battery: étape 1, image 2 de 3 RCA RCT6303W87 Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Battery Replacement: étape 2, image 1 de 1
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. RCA RCT6303W87 Battery Replacement: étape 3, image 1 de 3 RCA RCT6303W87 Battery Replacement: étape 3, image 2 de 3 RCA RCT6303W87 Battery Replacement: étape 3, image 3 de 3
    • Remove cover completely.
  4. RCA RCT6303W87 Battery Replacement: étape 4, image 1 de 3 RCA RCT6303W87 Battery Replacement: étape 4, image 2 de 3 RCA RCT6303W87 Battery Replacement: étape 4, image 3 de 3
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Battery Replacement: étape 5, image 1 de 3 RCA RCT6303W87 Battery Replacement: étape 5, image 2 de 3 RCA RCT6303W87 Battery Replacement: étape 5, image 3 de 3
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Battery Replacement: étape 6, image 1 de 3 RCA RCT6303W87 Battery Replacement: étape 6, image 2 de 3 RCA RCT6303W87 Battery Replacement: étape 6, image 3 de 3
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Battery Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Battery Replacement: étape 8, image 1 de 3 RCA RCT6303W87 Battery Replacement: étape 8, image 2 de 3 RCA RCT6303W87 Battery Replacement: étape 8, image 3 de 3
    • Carefully peel off the battery.
15 autres ont terminé cette réparation.
Akitaka Hashimoto
Membre depuis le 03/27/18
525 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G2, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G2, Harley Spring 2018
IUPUI-HARLEY-S18S3G2
3 membres
2 tutoriels rédigés
5 commentaires
Thank you very much for the instructions. I was totally in the blind about what to unplug or not.
Diamante Swift - Réponse
“Remove nine 4.8mm screws “ but you only show pictures of 7 screws.
George Phillips - Réponse
2 are hidden under the black hinge. you would have to remove the 3 tiny screw in order to get access to the hidden 2 screws.
Ed Barry -
Thanks for the instructions. I don’t know if mine is newer or older but the bus cable turns 90 degrees and goes under the keyboard cable so step 6 really wasn’t necessary. A plastic putty knife slid under old battery loosening the adhesive so you can slide it out from under the bus cable.
Steve Bunce - Réponse
Super helpful- worked great!
denise turley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 32
Total : 5,958
