Introduction
This replacement guide will teach you how to replace a worn speaker. This will ensure the device has quality sound. If the speaker has not fixed the issue there may be an electrical shortage in the device.
Push down on the clip to release pressure. The pull off the plastic cover. Push down on the clip to release pressure. The pull off the plastic cover.
  • Push down on the clip to release pressure. The pull off the plastic cover.
Ajouter un commentaire
Remove  the 9-volt battery from the battery terminal.
  • Remove the 9-volt battery from the battery terminal.
Take out the six screws located on the back of the device.
  • Take out the six screws located on the back of the device.
  • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
  • Three screws are located on the back panel. One is located inside the battery carriage.
  • Two screws are located on the on the back panel on the bottom left and right side.
Remove the 10 mm Phillip's #1 screw. Then remove the metal reinforcement. Then remove the metal reinforcement.
  • Remove the 10 mm Phillip's #1 screw.
  • Then remove the metal reinforcement.
Using flathead screwdriver undo the release tabs. Using flathead screwdriver undo the release tabs.
  • Using flathead screwdriver undo the release tabs.
Pry the release tabs with a spudger. Start with back of the device on the topside. Start with back of the device on the topside.
  • Pry the release tabs with a spudger.
  • Start with back of the device on the topside.
Pry open both tabs to remove the topside of the clock. Pry open both tabs to remove the topside of the clock.
  • Pry open both tabs to remove the topside of the clock.
Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
  • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
Myles Waiters
Membre depuis le 22/09/2014
337 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 10-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 95
