Aller au contenu principal
RCA Small Wonders Camcorder CC176 Viewfinder Replacement
Ce dont vous avez besoin
  1. RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: étape 1, image 1 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: étape 1, image 2 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement, Viewfinder: étape 1, image 3 de 3
    • Remove the 5 screws that secure the control panel (located on the top of the device) by using your small flathead screwdriver.
    • Loosen the panel from the device until you are able to remove it.
  2. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: étape 2, image 1 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: étape 2, image 2 de 3 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: étape 2, image 3 de 3
    • Remove the remaining 21 screws on the camcorder.
    • Begin separating the plastic casing from the inner components of the device.
  3. RCA Small Wonders Camcorder CC176 Viewfinder Replacement: étape 3, image 1 de 2 RCA Small Wonders Camcorder CC176 Viewfinder Replacement: étape 3, image 2 de 2
    • Grasping the viewfinder in hand, carefully remove the two screws that secure the mounting device.
    • Locate the gray electrical cord that connects the viewfinder to the inner components of the camera. Gently unplug the gray cord and loosen the viewfinder from the device.
    • Separate the viewfinder from the device and feed the gray cord through the hole in the plastic casing.
Allison Baudoin
Membre depuis le 12/05/11
401 Réputation
4 tutoriels rédigés
Équipe
James Madison, Team 2-1, Allen Fall 2011 Membre de l'équipe James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 16
Total : 1,286
