Aller au contenu principal
Raleigh M20 Bicycle Rear Rack Replacement
Ce dont vous avez besoin
  1. Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: étape 1, image 1 de 2 Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: étape 1, image 2 de 2
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Raleigh M20 Bicycle Rear Rack Replacement: étape 2, image 1 de 3 Raleigh M20 Bicycle Rear Rack Replacement: étape 2, image 2 de 3 Raleigh M20 Bicycle Rear Rack Replacement: étape 2, image 3 de 3
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
  3. Raleigh M20 Bicycle Rear Rack Replacement: étape 3, image 1 de 3 Raleigh M20 Bicycle Rear Rack Replacement: étape 3, image 2 de 3 Raleigh M20 Bicycle Rear Rack Replacement: étape 3, image 3 de 3
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
  4. Raleigh M20 Bicycle Rear Rack Replacement: étape 4, image 1 de 2 Raleigh M20 Bicycle Rear Rack Replacement: étape 4, image 2 de 2
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
To detach the rear rack, follow the instructions of this guide in the reverse order.
Alyssa Compania
Membre depuis le 09/26/12
86 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-49, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,984
