Introduction
The guitar keys can wear out over time or stop working completely. This guide demonstrates how to successfully remove the keys to diagnose internal problems.
Pièces
Aucune pièce nécessaire.
Remove the strap by pulling it off of the mounts located on the body and neck. Remove the strap by pulling it off of the mounts located on the body and neck.
  • Remove the strap by pulling it off of the mounts located on the body and neck.
Ajouter un commentaire
Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a  screwdriver. Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver. Pull off the rear case.
  • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
  • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
  • Pull off the rear case.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the five 12mm Phillips #1 screws along the neck with a  screwdriver. Pull off the top shell of the neck to expose the internal features. Pull off the top shell of the neck to expose the internal features.
  • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
  • Pull off the top shell of the neck to expose the internal features.
Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board. Lift up on the key sensor board to remove it from the guitar neck. When using the screwdriver, make sure to avoid puncturing the wires.
  • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
  • Lift up on the key sensor board to remove it from the guitar neck.
  • When using the screwdriver, make sure to avoid puncturing the wires.
Using your fingers, remove the rubber pad to expose the colored keys.
  • Using your fingers, remove the rubber pad to expose the colored keys.
Reach one finger under the guitar to push the key out of the casing. Repeat this step for the four remaining keys.
  • Reach one finger under the guitar to push the key out of the casing.
  • Repeat this step for the four remaining keys.
Ashley Slocum
Membre depuis le 18/04/2018
147 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 88
