Introduction
The whammy bar spring can dislodge from its mounts causing the bar to lose tension. This guide will show you how to replace the whammy bar spring.
Ce dont vous avez besoin
Remove the strap by pulling it off of the mounts located on the body and neck.
Remove the two 7mm Phillips #2 screws from the black wire retainer.
Pull off the black wire retainer.
3 autres ont terminé cette réparation.
