Aller au contenu principal
RedOctane X-Plorer Whammy Bar Replacement
Ce dont vous avez besoin
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: étape 1, image 1 de 2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: étape 2, image 1 de 3 RedOctane X-Plorer Whammy Bar Replacement: étape 2, image 2 de 3 RedOctane X-Plorer Whammy Bar Replacement: étape 2, image 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: étape 3, image 1 de 3 RedOctane X-Plorer Whammy Bar Replacement: étape 3, image 2 de 3 RedOctane X-Plorer Whammy Bar Replacement: étape 3, image 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: étape 4, image 1 de 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: étape 4, image 2 de 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: étape 4, image 3 de 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: étape 5, image 1 de 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: étape 6, image 1 de 2 RedOctane X-Plorer Whammy Bar Replacement: étape 6, image 2 de 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: étape 7, image 1 de 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: étape 8, image 1 de 1
    • Using two hands, remove the spring from the plastic tabs.
3 autres ont terminé cette réparation.
[deleted]
Membre depuis le 04/18/18
175 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 22
30 derniers jours : 92
Total : 3,550
