Aller au contenu principal
RedOctane X-Plorer Whammy Bar Sensor Replacement
Ce dont vous avez besoin
  1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: étape 1, image 1 de 2 RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 2, image 1 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 2, image 2 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 2, image 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 3, image 1 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 3, image 2 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 3, image 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: étape 4, image 1 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: étape 4, image 2 de 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: étape 4, image 3 de 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 5, image 1 de 2 RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 5, image 2 de 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Sensor Replacement: étape 6, image 1 de 1
    • Using two hands, remove the whammy bar sensor.
Riley
Membre depuis le 04/18/18
649 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S17-G1, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 21
Total : 935
