Aller au contenu principal
Removing 1985-1988 Volvo 740 Throttle Body
Ce dont vous avez besoin
  1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 1 de 2 Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 2 de 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Removing 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: étape 2, image 1 de 1
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Removing 1985-1988 Volvo 740 Throttle Body: étape 3, image 1 de 1
    • Locate throttle linkage cable assembly.
  4. Removing 1985-1988 Volvo 740 Throttle Body: étape 4, image 1 de 2 Removing 1985-1988 Volvo 740 Throttle Body: étape 4, image 2 de 2
    • Twist the assembly clockwise.
  5. Removing 1985-1988 Volvo 740 Throttle Body: étape 5, image 1 de 1
    • Slide both slackened cables off assembly’s guides.
  6. Removing 1985-1988 Volvo 740 Throttle Body: étape 6, image 1 de 2 Removing 1985-1988 Volvo 740 Throttle Body: étape 6, image 2 de 2
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Removing 1985-1988 Volvo 740 Throttle Body: étape 7, image 1 de 1
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Removing 1985-1988 Volvo 740 Throttle Body: étape 8, image 1 de 1
    • Remove the intake tube from the throttle body.
  9. Removing 1985-1988 Volvo 740 Throttle Body: étape 9, image 1 de 1
    • Locate wiring clip on the underside of the throttle body.
  10. Removing 1985-1988 Volvo 740 Throttle Body: étape 10, image 1 de 2 Removing 1985-1988 Volvo 740 Throttle Body: étape 10, image 2 de 2
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Removing 1985-1988 Volvo 740 Throttle Body: étape 11, image 1 de 3 Removing 1985-1988 Volvo 740 Throttle Body: étape 11, image 2 de 3 Removing 1985-1988 Volvo 740 Throttle Body: étape 11, image 3 de 3
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Removing 1985-1988 Volvo 740 Throttle Body: étape 12, image 1 de 3 Removing 1985-1988 Volvo 740 Throttle Body: étape 12, image 2 de 3 Removing 1985-1988 Volvo 740 Throttle Body: étape 12, image 3 de 3
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Removing 1985-1988 Volvo 740 Throttle Body: étape 13, image 1 de 1
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
Raymond
Membre depuis le 10/11/10
76 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-28, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 12
Total : 4,572
