Introduction
This guide will show how to remove the back cover.
Pièces
Aucune pièce nécessaire.
Remove the six external screws from the camera using a Phillips #0 screwdriver. After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera. Be careful, make sure you don't lose the screws.
  • Remove the six external screws from the camera using a Phillips #0 screwdriver.
  • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
  • Be careful, make sure you don't lose the screws.
Ajouter un commentaire
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Carefully squeeze the top right corner of the camera and pry off the external cover.
  • Carefully squeeze the top right corner of the camera and pry off the external cover.
  • If you hear a "cracking" sound. This is normal.
  • Continue to pull the external cover and it will come off cleanly.
  • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
Carefully pull off the back cover, parts behind the back of the case might fall out.
  • Carefully pull off the back cover, parts behind the back of the case might fall out.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Hasit
Membre depuis le 15/04/2010
168 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-17, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 3,301
