Pièces
Aucune pièce nécessaire.
Turn the laptop so that the bottom is facing up.
  • Turn the laptop so that the bottom is facing up.
  • Locate the panel that has an M on it and two air vents.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel. Put this screw in a bag or easily identifiable place.
  • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
  • Put this screw in a bag or easily identifiable place.
  • Remove the panel.
After removing the panel, you will see two memory modules. Locate the four spring clips that are holding the memory modules in place. Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
  • After removing the panel, you will see two memory modules.
  • Locate the four spring clips that are holding the memory modules in place.
  • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
  • Gently raise the memory module and lift it out of its socket.
Christopher
Membre depuis le 27/04/2010
8 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 16-2, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 5,426
