Introduction
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
Pièces
Aucune pièce nécessaire.
Turn the laptop upside down and  locate the panel labeled C. Unscrew the single screw holding the cover in place. lift up the cover and remove it to exposed the Wireless MiniPCI Card.
  • Turn the laptop upside down and locate the panel labeled C.
  • Unscrew the single screw holding the cover in place.
  • lift up the cover and remove it to exposed the Wireless MiniPCI Card.
Ajouter un commentaire
Using a plastic spudger or similar, gently pry the grey and black wires off. The grey and black wires are the antenna wires so be careful not to damage them
  • Using a plastic spudger or similar, gently pry the grey and black wires off.
  • The grey and black wires are the antenna wires so be careful not to damage them
  • Gently pull the retaining clips away from the board so that the board pops up.
Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
  • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Teja
Membre depuis le 27/04/2010
98 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 16-2, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 5,450
