Aller au contenu principal
Delphi MyFi XM2GO Motherboard Replacement
Ce dont vous avez besoin
  1. Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: étape 1, image 1 de 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: étape 1, image 2 de 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: étape 1, image 3 de 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Delphi MyFi XM2GO Motherboard Replacement, Battery: étape 2, image 1 de 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: étape 2, image 2 de 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: étape 2, image 3 de 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Delphi MyFi XM2GO Motherboard Replacement, Motherboard: étape 3, image 1 de 2 Delphi MyFi XM2GO Motherboard Replacement, Motherboard: étape 3, image 2 de 2
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Delphi MyFi XM2GO Motherboard Replacement: étape 4, image 1 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 4, image 2 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 4, image 3 de 3
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Delphi MyFi XM2GO Motherboard Replacement: étape 5, image 1 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 5, image 2 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 5, image 3 de 3
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Delphi MyFi XM2GO Motherboard Replacement: étape 6, image 1 de 2 Delphi MyFi XM2GO Motherboard Replacement: étape 6, image 2 de 2
    • Remove the back cover.
  7. Delphi MyFi XM2GO Motherboard Replacement: étape 7, image 1 de 2 Delphi MyFi XM2GO Motherboard Replacement: étape 7, image 2 de 2
    • Remove the power button by pulling it to the left.
  8. Delphi MyFi XM2GO Motherboard Replacement: étape 8, image 1 de 2 Delphi MyFi XM2GO Motherboard Replacement: étape 8, image 2 de 2
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Delphi MyFi XM2GO Motherboard Replacement: étape 9, image 1 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 9, image 2 de 3 Delphi MyFi XM2GO Motherboard Replacement: étape 9, image 3 de 3
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
Scott Byer
Membre depuis le 03/09/12
61 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 1-2, Benson Spring 2012 Membre de l'équipe Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,484
