Aller au contenu principal
Removing Fender Frontman 15r Back panel
Ce dont vous avez besoin
  1. Removing Fender Frontman 15r Back panel, Back panel: étape 1, image 1 de 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Removing Fender Frontman 15r Back panel: étape 2, image 1 de 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Removing Fender Frontman 15r Back panel: étape 3, image 1 de 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
Greg Sawers
Membre depuis le 09/27/12
91 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-30, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 membres
7 tutoriels rédigés
Un commentaire
I need to know where to find a used circuit board for my Fender Frontman 15G. A circuit board from a Fender Frontman 15R will also work. Please help me.
sparkyman401 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 33
Total : 6,676
