Aller au contenu principal
Removing HP Compaq dx2000MT CPU Cooler
Ce dont vous avez besoin
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: étape 1, image 1 de 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: étape 2, image 1 de 2 Removing HP Compaq dx2000MT CPU Cooler: étape 2, image 2 de 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: étape 3, image 1 de 3 Removing HP Compaq dx2000MT CPU Cooler: étape 3, image 2 de 3 Removing HP Compaq dx2000MT CPU Cooler: étape 3, image 3 de 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: étape 4, image 1 de 3 Removing HP Compaq dx2000MT CPU Cooler: étape 4, image 2 de 3 Removing HP Compaq dx2000MT CPU Cooler: étape 4, image 3 de 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: étape 5, image 1 de 2 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: étape 5, image 2 de 2
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: étape 6, image 1 de 2 Removing HP Compaq dx2000MT CPU Cooler: étape 6, image 2 de 2
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: étape 7, image 1 de 2 Removing HP Compaq dx2000MT CPU Cooler: étape 7, image 2 de 2
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
2 autres ont terminé cette réparation.
Logan Pace
Membre depuis le 10/12/11
2 251 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 17-16, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 35
Total : 5,480
