Introduction
This guide will show you how to remove a PCI card on your HP Compaq dx2000MT.
Turn off your computer and remove the power cable by pulling it straight out of its socket.
  • Turn off your computer and remove the power cable by pulling it straight out of its socket.
Ajouter un commentaire
Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
  • Remove the 2 Phillips #2 screws that secure the case door to the device.
Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
  • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
  • Once you slide the door back, remove it by pulling it outwards from the device.
Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
Remove the Torx T15 screwdriver holding the PCI card in place. Remove the Torx T15 screwdriver holding the PCI card in place.
  • Remove the Torx T15 screwdriver holding the PCI card in place.
Remove the PCI card by pulling it out towards the side of the device.
  • Remove the PCI card by pulling it out towards the side of the device.
  • Be careful about touching the top and bottom of the card! The static electricity in your fingers could short it. If you can, only touch the metal bracket and the sides of the card.
6 autre(s) ont terminé cette réparation.
Logan Pace
Membre depuis le 12/10/2011
2 020 Réputation
15 tutoriels rédigés
Équipe
Cal Poly, Team 17-16, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 membres
17 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 43
Total : 4,097
