Introduction
Removing and replacing the DVD-ROM drive.
Pièces
Aucune pièce nécessaire.
Pull on outer latch. Lower door until it is level with your work surface.
  • Pull on outer latch.
  • Lower door until it is level with your work surface.
  • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
Ajouter un commentaire
Removing the faceplate. On the inside of the case, find the two plastic tabs.
  • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
Pull the drive out to allow access to the power and ribbon cables. Do not fully remove. Remove both the power and ribbon cable. Remove both the power and ribbon cable.
  • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
  • Remove both the power and ribbon cable.
Ligne d'arrivée
23 autre(s) ont terminé cette réparation.
Justin Petrilli
Membre depuis le 21/01/2010
2 598 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
13 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 8,412
