Aller au contenu principal
Removing RAM from HP Elitebook 6930p
Ce dont vous avez besoin
  1. Removing RAM from HP Elitebook 6930p, Battery Removal: étape 1, image 1 de 3 Removing RAM from HP Elitebook 6930p, Battery Removal: étape 1, image 2 de 3 Removing RAM from HP Elitebook 6930p, Battery Removal: étape 1, image 3 de 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing RAM from HP Elitebook 6930p, Keyboard: étape 2, image 1 de 3 Removing RAM from HP Elitebook 6930p, Keyboard: étape 2, image 2 de 3 Removing RAM from HP Elitebook 6930p, Keyboard: étape 2, image 3 de 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing RAM from HP Elitebook 6930p: étape 3, image 1 de 3 Removing RAM from HP Elitebook 6930p: étape 3, image 2 de 3 Removing RAM from HP Elitebook 6930p: étape 3, image 3 de 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing RAM from HP Elitebook 6930p: étape 4, image 1 de 3 Removing RAM from HP Elitebook 6930p: étape 4, image 2 de 3 Removing RAM from HP Elitebook 6930p: étape 4, image 3 de 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing RAM from HP Elitebook 6930p, RAM: étape 5, image 1 de 2 Removing RAM from HP Elitebook 6930p, RAM: étape 5, image 2 de 2
    • Locate RAM module
    • Push metal tabs outwards away from the RAM module to release it.
    • The RAM module will spring up and can be removed from the RAM slot.
21 autres ont terminé cette réparation.
Richdave
Membre depuis le 04/09/10
32 177 Réputation
30 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 468 tutoriels rédigés
7 commentaires
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
astorp2000 - Réponse
I agree with above comment, weird thing to do.
S Cleaver - Réponse
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Andy Mitchell - Réponse
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
Been Allison - Réponse
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
Lukasz Nowakowski - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 71
Total : 30,662
